Xantia sills.
daviemck2006
x 485
Xantia sills.
Unread post by daviemck2006 »
Can anyone tell me what the hole in the outer sill about 4 inches behind the front wheels and plugged with a rubber seal is for. I ask as I had a welder have a quick look at my car yesterday to see what bits need welding. At first look there is the passenger door shut which the guy says will be much easier and a better job with a donor bit, both of said holes in the sill, the question is just patch over or have to fabricate over, and two small holes in the floorpan on drivers side. That was just a quick look with the car on the ground, he is off on holiday so I have to go see him in a couple weeks when it shall go up on the ramp for a thorough look. He did say he would be able to do the door shut without a donor bit, but the finish would not be so great, which for me would not be the end of the world as it's not seen apart from when the door is open, but obviously the neater the repair is the better. So again anyone breaking one and the left side door shut is good please message me if you could take a grinder and cut a bit out for me.
Davie
Sent from my SM-G361F using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 1995
Re: Xantia sills.
Unread post by Stickyfinger »
These may help, from the THATCHAM repair procedure book. the welding should follow as described.
Sorry, scanner is bust
daviemck2006
x 485
Re: Xantia sills.
Thanks. My printer is kaput lol. I'll print these off at my daughter's and give them to the guy, see if it guides him any. I really hope there's no more underneath
Peugeot boxer 2016
In the family
x 1995
Re: Xantia sills.
If needed I can send the book up David......BUT will kill you, your family and your goldfish if you loose it :)
daviemck2006
x 485
Re: Xantia sills.
Well I don't have a goldfish, I will happily show you my son, but I really want my daughter's and grandaughters to be ok so I spose I'll just print those photos of the pages and see if that helps the guy. I think even that should give him some pointers
Peugeot boxer 2016
In the family
daviemck2006
x 485
Re: Xantia sills.
I suppose outer sills will be NFP nowadays. A phone call to a dealer needed in the near future will be required. If there is the start of patching on them, may be as well biting the bullet and doing the lot, to make a better job of it when the mechanics of it and the rest of the body is so good.
Peugeot boxer 2016
In the family
KennyW
x 165
Re: Xantia sills.
Unread post by KennyW »
Davie,
There is few companies that still do sills. I remember searching and finding a dutch company which did them. I cannot remember there name.
Kenny
C3 1.4 petrol (SWMBO)
daviemck2006
x 485
Re: Xantia sills.
I'll have a search on the internet in the next few days and see what I can find. It's just my way of thinking. It doesn't need sills, but it could be 1 wee patch here, another there and in a couple of years it could be a mess of patches. Do a bigger job properly just now and fix the possibility of more problems in the future. That's what we did on the boat when I had a share of it. Fix the problems properly and it cost less for maintenance in the long run. And considering I want to keep this car it seems the right thing to do.
Peugeot boxer 2016
In the family
c.morewood
x 55
Re: Xantia sills.
Unread post by c.morewood »
Hi Davie, I'm at work at the moment and unlikely to be online for the next couple of days. But if you search my posts, about a year ago, you'll find a link to somewhere which does complete sills for the Xantia. If you'd like to take a trip up to Shetland, I know where there are 3 xantias awaiting cubing.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
c.morewood
x 55
Re: Xantia sills.
Hi Davie,
Sorry to take so long to get back. The company is http://carz2.co.uk/ When I made the enquiry 2 years ago it was £63.30 for one sill delivered.
Hope this helps,
'94 Fiat TipoTd 40K
daviemck2006
x 485
Re: Xantia sills.
Thanks Chris. I've just had a quick look, still available at £46, did not check delivery. That's one option covered then.
Peugeot boxer 2016
In the family
x 1489
Re: Xantia sills.
No longer available from Citroen - but that's probably a good thing since they wanted >£250 a side :shock: :twisted:
x 1995
Re: Xantia sills.
What about the inner panels ?
daviemck2006
x 485
Re: Xantia sills.
I haven't found them. If the sills are just starting to go then possibly the inner panels are ok, but then if it's started from inside they could be gone. It might be ok fabricating bits for them as they are never seen.
Peugeot boxer 2016
In the family
x 1489
Re: Xantia sills.
All listed as available except the rear section of the RH middle section (there's inner, middle and outer sections; the middle section is in 2 parts) 73 and 74 are the front sections (left / right) , 75 and 76 the rear (left / right). Same parts MK1 and MK2.
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00007007Q4 INT SIDEMEMBER 56.02 GBP 67.22 GBP 67.22 GBP
00007008J8 INT SIDEMEMBER 56.02 GBP 67.22 GBP 67.22 GBP
95668073 SIDEMEMBER 80.34 GBP 96.41 GBP 96.41 GBP
95668074 SIDEMEMBER 80.34 GBP 96.41 GBP 96.41 GBP
95668075 SIDEMEMBER 80.34 GBP 96.41 GBP 96.41 GBP
95668076 SIDEMEMBER 80.34 GBP 96.41 GBP 96.41 GBP
