C5 X7 tyre pressure monitoring
rmunns
x 9
Unread post by rmunns »
I was reading about how the system works and soon found out that there are potential problems, often resulting from leaks or faults. I am just about to have fitted 4 new tyres (Goodyear efficientgrip performance) and I am thinking of having new sensors fitted at the same time. On eBay they are available at about £6 each. I'm unsure what do do - what's the recommendation? I have had the car for a year and have had the warning on the same wheel 4 or 5 times, always putting it down to a slow puncture which wasn't worth fixing in view of the tyre's end-of-life anyway. But now I suspect the problem could be a leak or a fault.
If I do decide to have the tyre fitters change the sensors (good or bad idea?) then does some software setting have to be changed? It seems a sensible time to renew the sensors.
vborovic
Locked user account
x 40
Re: C5 X7 tyre pressure monitoring
Unread post by vborovic »
rmunns wrote:£6 each
Maybe you meant 60 ?
x 2000
Unread post by Stickyfinger »
It could be the stem leaking.
There is a nut on the stem which can loosen....try tightening it up. You can check it by rotating the wheel so the valve is on the road edge, apply 50/50 washing-up liquid and water see if it bubbles.
x 6947
rmunns wrote:If I do decide to have the tyre fitters change the sensors (good or bad idea?) then does some software setting have to be changed? It seems a sensible time to renew the sensors.
I wouldn't get them done at a tyre fitters personally, there is a procedure to get these programmed and working on the X7 - see below:
Programming / Initialisation
A programming procedure is compulsory fo the following components:
  • Wheel Transmitter Module
  • Main set of wheel transmitter modules
  • One additional set of wheel transmitter modules
The programming procedure requires the use of a special tool 'Tyre Inflation Valve Forcer'.
Programming Procedure:
  • Overinflate the wheel to be programmed to 3.7 Bars
  • Wait one minute
  • Deflate the wheel to reach the standard inflation pressure recommended by the manufacturer
  • Fit the special 'Tyre Inflation Valve Forcing tool' onto the valve in order to inform the tool of the new pressure value in the wheel.
"This operation must be carried out for each wheel when programming a complete set of wheel transmitter modules or rotating wheels". As stated in the Procedure.
x 6947
rmunns wrote: I am thinking of having new sensors fitted at the same time. On eBay they are available at about £6 each.
These aren't the sensors, they are the valve repair kits Roger and are about £6
These are the TPMS Sensors and they are a tad under £60 as Vab says:
http://www.ebay.co.uk/itm/GENUINE-PEUGE ... 8rOsxDvlpw
x 1943
Unread post by Paul-R »
No mention of an exciter needed. Or is that what the forcer is? AFAIK an exciter is simply held neat to a TPMS valve and then operated. Is it not needed now?
x 6947
That's what is listed for the X7 Paul, they don't seem to mention the 'Exciter' - and they need to be paired to the car using the Lexia when fitting new sensors according to the Docs.
x 1943
Wonder what's involved with this forcer? The exciter is basically a low powered transmitter on a low frequency (125KHz IIRC) which prompts the TPMS to signal to the onboard car system. I'm wondering if it's the same thing? Is there a reference to a trade name for this exciter such as Protoctair?
x 1943
Or something called Testair as the Protoctair mini seems to be NLA?
x 6947
No it just mentions as per what I've put in quotes - no mention of names...
rmunns
x 9
Thanks, everyone. I'll leave well alone........................
x 1943
Ah, but you've started something now.
This thread will run and run...
x 6947
I'll have another dig later to see if there are differences between the MK1 / MK2 and the X7 procedures.
rmunns
x 9
I had a flash of common sense (unusual for me!). (I guess this is an obvious thing to do) - I just used some detergent water and a brush, to check if there is a leak anywhere near the valves. I can't see any, so hopefully I really do have a slow puncture in the one tyre.
x 2000
may I draw you to the third post in this thread :)
