C5 X7 tyre pressure monitoring
rmunns
- x 9
I was reading about how the system works and soon found out that there are potential problems, often resulting from leaks or faults. I am just about to have fitted 4 new tyres (Goodyear efficientgrip performance) and I am thinking of having new sensors fitted at the same time. On eBay they are available at about £6 each. I'm unsure what do do - what's the recommendation? I have had the car for a year and have had the warning on the same wheel 4 or 5 times, always putting it down to a slow puncture which wasn't worth fixing in view of the tyre's end-of-life anyway. But now I suspect the problem could be a leak or a fault.
If I do decide to have the tyre fitters change the sensors (good or bad idea?) then does some software setting have to be changed? It seems a sensible time to renew the sensors.
vborovic
- Locked user account
- x 40
Re: C5 X7 tyre pressure monitoring
Maybe you meant 60 ?rmunns wrote:£6 each
- x 2004
It could be the stem leaking.
There is a nut on the stem which can loosen....try tightening it up. You can check it by rotating the wheel so the valve is on the road edge, apply 50/50 washing-up liquid and water see if it bubbles.
- x 6947
I wouldn't get them done at a tyre fitters personally, there is a procedure to get these programmed and working on the X7 - see below:rmunns wrote:If I do decide to have the tyre fitters change the sensors (good or bad idea?) then does some software setting have to be changed? It seems a sensible time to renew the sensors.
Programming / Initialisation
A programming procedure is compulsory fo the following components:
- Wheel Transmitter Module
- Main set of wheel transmitter modules
- One additional set of wheel transmitter modules
Programming Procedure:
- Overinflate the wheel to be programmed to 3.7 Bars
- Wait one minute
- Deflate the wheel to reach the standard inflation pressure recommended by the manufacturer
- Fit the special 'Tyre Inflation Valve Forcing tool' onto the valve in order to inform the tool of the new pressure value in the wheel.
- x 6947
These aren't the sensors, they are the valve repair kits Roger and are about £6rmunns wrote: I am thinking of having new sensors fitted at the same time. On eBay they are available at about £6 each.
These are the TPMS Sensors and they are a tad under £60 as Vab says:
http://www.ebay.co.uk/itm/GENUINE-PEUGE ... 8rOsxDvlpw
- x 1944
No mention of an exciter needed. Or is that what the forcer is? AFAIK an exciter is simply held neat to a TPMS valve and then operated. Is it not needed now?
- x 6947
That's what is listed for the X7 Paul, they don't seem to mention the 'Exciter' - and they need to be paired to the car using the Lexia when fitting new sensors according to the Docs.
- x 1944
Wonder what's involved with this forcer? The exciter is basically a low powered transmitter on a low frequency (125KHz IIRC) which prompts the TPMS to signal to the onboard car system. I'm wondering if it's the same thing? Is there a reference to a trade name for this exciter such as Protoctair?
- x 1944
Or something called Testair as the Protoctair mini seems to be NLA?
- x 6947
No it just mentions as per what I've put in quotes - no mention of names...
rmunns
- x 9
Thanks, everyone. I'll leave well alone........................
- x 1944
Ah, but you've started something now.
This thread will run and run...
- x 6947
I'll have another dig later to see if there are differences between the MK1 / MK2 and the X7 procedures.
rmunns
- x 9
I had a flash of common sense (unusual for me!). (I guess this is an obvious thing to do) - I just used some detergent water and a brush, to check if there is a leak anywhere near the valves. I can't see any, so hopefully I really do have a slow puncture in the one tyre.
- x 2004
may I draw you to the third post in this thread
