Hi
I got used top strut , how can I know its Citroen part number ? Are there any external signs that links the strut top to its Citroen part number ?
Is there any major difference between the various strut tops but the threading standard ?
Xantia - Identifing strut top part number
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
- x 8
Re: Xantia - Identifing strut top part number
Any help please ?
Zohar
Zohar
- x 6950
I can look for the PSA part numbers for you, but I'll need your VIN.
- x 1484
I don't think that there is any way to determine the part number of a strut top unless you know the model and build date of the car it came from. If it looks the same as the one you are removing, and the threads and strut hole are the same size, it will probably be OK.
superloopy
- x 19
I also wondered why so many different strut tops if they are mainly the same under the skin. There has to be more to it?
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
lancia58
- x 8
Hi Marc
I have the part number for may cat. I just look for information regarding the different strut top , and if I can link between the used strut I got and their part number. Some numbers/letter are coined on each of them but I didn't find a way to link it to their part number
Zohar
Zohar
