My Xantia HDi Shed
Supernaut
x 4
My Xantia HDi Shed
Unread post by Supernaut »
So I got my Xantia.
It's a W reg HDi, with 78k on the clocks and an MOT until next April and stacks of service history. Cosmetically, it's a bit of a shed but everything on it works perfectly, even the air con!
Apart from the driver's seat, the interior is iimaculate. I'll service it at the weekend (oil, oil filter, air filter, plus I've got all-round brake pads).
I already did a couple of repairs on it yesterday, using nothing but loads of contact cleaner. The heater blower fan was inoperative, so I completely dis-assembled it and gave it a load of contact cleaner. The airbag light was blinking too, so I disconnected the battery and cleaned up the connectors under the front seats. No more blinking airbag light!
My plan is simply to drive it as it is and enjoy it (well, looking into a stage 1 map). Who cares about cosmetics?! :-D
chinkostu
x 30
Re: My Xantia HDi Shed
Unread post by chinkostu »
Hey you're on reddit too!
Get some leathers in there you won't regret it
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
Supernaut
x 4
Heh, yeah I'm on reddit.
Leathers do sound tempting. I reckon Peugeot 306 front seats would fit...
Mainly because I know that 306 seats fit a 405, and 405 seats fit a Xantia, so surely by that logic 306 seats should fit a Xantia!
van ordinaire
(Donor 2017)
x 402
Supernaut wrote: I reckon Peugeot 306 front seats would fit...
Just love that logic :-D
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
chinkostu
x 30
Should do!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
Supernaut
x 4
Update time!
Still not done the seat.
However, I've serviced it, remapped it, replaced all the brakes pads (plus copper-greased every moving part on the brakes) and got 4 new tyres and an alignment.
The car now drives a billionty times better than it looks! I think I want to get some proper old-school metal wheel trims / hubcaps for it then just drive it as-is.
x 8386
How did you remap it?
Supernaut
x 4
To do a remap, one requires a Galetto lead, or an MPSS lead.
Then, you buy a map and flash it on yourself. I know of a couple of people who do it from my past times on Peugeot 306 forums (I used to have a Ph3 306 HDi estate, which I also mapped).
I bought a stage 1 map from hdi-tuning.co.uk, the guy who runs it is called Steve Lewis and he works really quickly! You take a copy of the original map from the ECU first (then keep it somewhere safe), and send him the original map so he can verify the model of ECU etc. etc. then he sends you a stage 1 that's compatible with it. You can only really do this on the Bosch ECUs though, if you have a Siemens you're out of luck I'm afraid.
superloopy
x 19
Unread post by superloopy »
Interesting. Go on ... give it a go Jim.
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
x 8386
Supernaut wrote:To do a remap, one requires a Galetto lead, or an MPSS lead.
Interesting, so not just one of those piggy-back tuning boxes then... So what difference have you noticed?
xantiamanic wrote:Go on ... give it a go Jim.
Can't. Not got an HDi..
Now if there was a map available for the TCT that upped the boost limit that would be good...
BenC5HDi
Not Mike
x 45
Unread post by BenC5HDi »
Supernaut wrote:. You can only really do this on the Bosch ECUs though, if you have a Siemens you're out of luck I'm afraid.
Not any more. Vinny from hdi-tuning.co.uk remapped my Siemens 801 ECU on my 2.0 HDi, with a stage 1 remap, up to 123bhp.
BenC5HDi
Not Mike
x 45
I'll show you on Tuesday in the Berlingo Jim when I drop Davie off. A huge difference!
x 8386
Knowing the huge difference between the 90 HDi and the 110HDi I can well imagine there is...
Supernaut
x 4
Well, after over a year of trouble-free motoring, I encountered a problem today.
I was greeted with this when I started it. This was taken with the engine running:
This prompted me to open the bonnet...
Oh, p**s!
I looked a bit closer...
So, what seems to be happening is that coolant is leaking out of a pinhole to the left edge of that indented circle below the thermostat housing. Liquid metal time, or is it a telltale to let me know the thermostat needs replaced? Help me out here.
I topped up the coolant level and it seems happy enough for now, but when up to temperature there's a fine spray coming out of the pinhole, covering the top hose and the inside of the radiator in sticky coolant residue!
It's a 2.0 HDi 8v 90hp, by the way.
EDIT: It seems to be a core plug. I've ordered a replacement already. This could be fun!
x 8386
Core plugs are easy enough to replace... Pull the old one out by screwing a meaty self-tapping screw into it and then use a claw-hammer or forked pry-bar to pull it out..
Clean up and carefully tap the new one home evenly and gently with a small hammer above a hard wooden pad...
