Xantia - Differences between rear suspension cylindres
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
What is the differences between the various rear suspension cylinders in particular the following:
5272 53
5272 22.
I can find both at Citroen.Service and know to which model each one fits, but just wander what are the differences ? In general why Citroen has to produce different suspension cylinders ( front and rear ) for different models ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 1484
Re: Xantia - Differences between rear suspension cylindres
Unread post by xantia_v6 »
Estate and hatchback have different cylinder bores. Hydractive has bigger pipe fittings. And Citroën changed the design of the pipe fitting at least once.
x 6950
With / without hydractive suspension for one, Engine types / weights / Saloon / Estate etc.
