Xantia - Cleaning the air intake throttle body
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I may to clean the air intake throttle body, is there a safe cleaning solvent that it can be dipped in ? Any precautions ? Of coarse the idle stepper motor , the throttle potentiometer and the air intake temperature sensor will be detached before
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 2008
Re: Xantia - Cleaning the air intake throttle valve house
Unread post by Stickyfinger »
"Carb" cleaner. Petrol (if the bits are off) with fine wire wool used with care near the butterfly
