Hi
I may to clean the air intake throttle body, is there a safe cleaning solvent that it can be dipped in ? Any precautions ? Of coarse the idle stepper motor , the throttle potentiometer and the air intake temperature sensor will be detached before
Zohar
Xantia - Cleaning the air intake throttle body
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 1987
Re: Xantia - Cleaning the air intake throttle valve house
"Carb" cleaner. Petrol (if the bits are off) with fine wire wool used with care near the butterfly
