AX 1.1i injection issue
jsp
x 12
Unread post by jsp »
I have a 1.1i from 1996. Recently I have an issue when the headlights are on.
The car starts juddering when the headlights are on when driven.
I have replaced the alternator few weeks ago.
jsp
x 12
Re: AX 1.1i injection issue
fuel problem sorted.
weak headlights anyone?
x 1438
Unread post by xantia_v6 »
The only thing you can do is measure the voltage across the bulbs, then work back in both directions (live and earth) to find the voltage drops. Or just fit a relay with heavy wires straight back to the battery...
jsp
x 12
Turns out to be a bad earthing cable from the battery to chassis.
