I have 2010 c5 crt+ nav. I have bought led lights to change the DLR bulbs, I cannot seem to get to the DLR bulb. Does the whole light unit have to be removed to do this?
thanks
DLR
Onlinemyglaren
- x 5688
Re: DLR
There have been a few headaches with these. In the first instance I recommend you read these threads and come back if your question isn't answered satisfactorily.
Welcome to the FCF
Welcome to the FCF
- x 1504
Re: DLR
Cit procedure is to remove the bumper, then the bulb is accessible from underneath the headlamp unit. Only an hour book time; but that would be for a new car where all the bolts for the bumper will come out!!
- x 2008
Re: DLR
Bumper removal
http://www.frenchcarforum.co.uk/forum/v ... 1&start=15
aidy999
Re: DLR
is this the only option to doing it?Stickyfinger wrote:Bumper removal
vborovic
- Locked user account
- x 40
Re: DLR
With the right tool and small hands, you can take the DRL bulbs out without any dismantling on the car:
http://www.frenchcarforum.co.uk/forum/v ... 15#p392236
aidy999
Re: DLR
is this the only option to doing it?vborovic wrote:With the right tool and small hands, you can take the DRL bulbs out without any dismantling on the car:
aidy999
Re: DLR
without starting to replace the drl bulbs are these the right ones?
http://www.ebay.co.uk/itm/291676509656? ... EBIDX%3AIT
- x 6950
Re: DLR
There's also a bit here when I did mine:aidy999 wrote:I have 2010 c5 crt+ nav. I have bought led lights to change the DLR bulbs, I cannot seem to get to the DLR bulb. Does the whole light unit have to be removed to do this?
thanks
http://www.frenchcarforum.co.uk/forum/v ... 15#p464087
The bulbs can be got to without removing the bumper, but it is likely that if they have never been removed and greased before, you will really struggle to get them out with the tool for the first time, as there just isn't the room. As I said in my post, I just paid the dealer to remove the old DRLs for me to break the seals and grease the socket for me. I then fitted the LED replacements later, once I had made the mods to the old bulb holder plastic lugs. Getting them in was a lot easier once they were greased. Using the cable tie to make a loop made getting them out a lot easier next time and prevents you dropping them. Plenty of info for you to digest and decide on which way you want to go.
