AX brake booster conversion plumbing
jsp
x 12
Unread post by jsp »
hi all,
I am converting my non brake boosted ax to one with brake booster.
I have one issue and that is the left front wheel brakes very retarded while the right wheel brakes instantly.
I have bleeded all throughly but, no brakes on my front left wheel.
Here is the brake lines I have set up:
RF LR
RR LF
What have I done wrong?
jsp
x 12
Re: AX brake booster conversion plumbing
I have plumbed it like this any other ideas?
jsp
x 12
I have connected like this. but, I have rear brake cilinders without limiter do I need one with auto. limiters?
jsp
x 12
Nobody knows this?
I bled the system three times now.
x 1504
Not exactly a normal problem! Have you taken a servo and master cylinder from a servo'd car and fitted it to a non servo car? Are the calipers the same? Presume you have fluid at the caliper that is not working? Does it work if you clamp off the other hoses?
jsp
x 12
Sorted. Connected the wrong rear lines on the wrong side on the main cylinder. working now without issues.
