Xantia TD Immbolizer
ecohouse1
x 3
Unread post by ecohouse1 »
Just out of interest around the immobilzer issues I am having with my Xanty TD, I have read that the stop solenoid area is armoured to keep it thief proof I presume. Why cant I just tap into the wiring to the armoured area to "over ride" the immobiliser? I realise that this cant be possible with all the posts about drilling off the armour etc but was just interested as I see two wires at the lower front of the Bosch pump on mine.
Cheers
Alan
x 8457
Re: Xantia TD Immbolizer
It is not as simple as that Alan :(
The pump-end of the immobiliser is piggy-backed over the top of the stop solenoid under the armour. The module makes a direct connection to the solenoid and it cannot be accessed external to the armour..
The only way is to de-armour the pump... That's very much a case of removing the pump from the engine.
This webpage shows the immobiliser module under the armour and gives one method of de-armouring...
It is certainly one way around the problem you have Alan..
bxzx16v
x 34
Unread post by bxzx16v »
Is it the keypad immobilizer your after info on ?
Mark
x 8457
bxzx16v wrote:Is it the keypad immobilizer your after info on ?
No, I believe Alan's TD is a late S2 with the RFID/Transponder immobiliser Mark...
bxzx16v
x 34
Ok thanks Jim .
Mark
KennyW
x 165
Unread post by KennyW »
Alan,
the good news is you do not need to remove the pump from the car but you must be careful of swarf when dealing with the protective bolts.
I used dremel with a cutting blade to puta slot in the head to turn it with a screw driver.
I'll find my long bosch pump thread where i talk about all my fun!!!!!!!!!!!!!
Kenny
C3 1.4 petrol (SWMBO)
x 8457
KennyW wrote: the good news is you do not need to remove the pump from the car but you must be careful of swarf when dealing with the protective bolts.
You're a braver man than me Kenny!!! =D> :)
KennyW
x 165
Jim,
you must remember the number of times I had the pump off and on, I got quite good at removing and refitting it.
x 8457
I do indeed Kenny, you did an excellent job :D
KennyW
x 165
Alan
http://www.frenchcarforum.co.uk/forum/v ... 12#p200206
Have a look at this thread. If you require photos let me know and shall add them to your thread.
Kenny
