X7 and diagbox Q's.....
old'uns
x 127
Unread post by old'uns »
as per title....next time anyone plugs theirs in, can you take a note of how to access live data, soot levels, additive ECU etc?
the additive option in particular at some time i 'may' have altered as i'm sure no additive is being injected?
i'm convinced that something has gone AWOL re electrickery connections
i spent 2 hrs yesterday having a play and for the life of me i can't get into the above, pretty sure i was able to with Lexia ?
i did manage to turn off the Autolight sensor as thats still playing up and reduce the low fuel level warning back to 7 litres after OH asked for 10 some months ago :lol:
we had the 55mph suspension warning AGAIN, Diagbox procedure followed, 3 litres of LDS in and the b*****d thing won't drag it's arse off the floor :x
left it overnight and rear will raise and drop but still have a Snowplough front end.
I fear that this may be last straw, i've thrown money at it but i think Citroen lost the plot reliability wise and so now the search has sort of started and probably won't be French
Sloppysod
x 407
Re: X7 and diagbox Q's.....
Unread post by Sloppysod »
3 litres is alot, if that much had come out then you would see oil on the ground where you would normally park it. The system is self bleading so air is not an issue, but I would check that the "Body Displacement sensors" are working as they should", correct setting, no broken or bent linkages, electrical connection are good .......just basic stuff like that first.
Once up, check the fluid level and syphon of any extra so you wont blow any seals.
Oh I know it may seem like a daft question, but when you either unlock the car of turn the ignition on, do you hear the pump start up, whirring noise from front of car?
## Remember to use axle-stands when working under a Hydropneumatic Citroen ##
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
osx
(Donor 2022)
x 15
Unread post by osx »
Is there any leak on the ground? You can also loose LDS from the steering rack and this will affect the suspension.
C5 X7 Exclusive 2.0 HDi Auto
old'uns
x 127
pump runs OK and so far after top-up is still fine.
can't see any new drops on drive at moment, however as there is little area that has no LDS on it....needle in haystack....
already had rack repaired so that won't get done again along with new ds front strut after 2 advisories at MOT time
anti pollution fault is now permanent hence why i need to double check settings for type of additive system and why i need to access live data, soot levels etc.
short list for replacement is moving along......Honda CR-V, Hyundai santa Fe, Rav4 so far
KP
x 27
Unread post by KP »
Crv is the most reliable one in CDTi form IMO, the Rav4's are also good but personally I'm put off by more modern Toyotas after a bad experience with them.
