Xantia fuse box and ECU box clip
x 2005
Unread post by Stickyfinger »
Hi guys......the things you discover whilst fiddling :)
My fuse box is distorted and the lid does not fit very well along the back edge (it is fitted correctly inside)....the "other" cars also have this problem, did they ever fit ?
Also, I am missing a clip (? metal) on the ECU box, again missing from the other cars, got a photo ?
Cheers
Mandrake
x 695
Re: Xantia fuse box and ECU box clip
Unread post by Mandrake »
The engine bay fuse box covers on all the Xantia's I've seen don't fit very well and seem to be distorted. As to whether it was like this new, I have no idea - the newest Xantia I ever owned was 8 years old!
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 8391
Yep, they're not the most wonderful.. Better than an XM though...
x 2005
Oh OK....I was guessing that....Quality moulding with quality plastic then :)
x 8391
Stickyfinger wrote:Quality moulding with quality plastic then :)
Yes, only the best was good enough for Citroen :wink:
x 1459
Unread post by xantia_v6 »
Stickyfinger wrote: Also, I am missing a clip (? metal) on the ECU box, again missing from the other cars, got a photo ?
Guessing that you are referring to the clip that holds the throttle cable? if so, I think that it was only fitted to RHD Mk1s with A/C (and probably only petrol engines).
x 2005
Nope, the clip on the leading edge of the ECU box to keep the lid on.
HDI
x 7
Unread post by HDI »
The fuse box can be awkward to refit correctly, so if an impatient mechanic has force fitted badly in the past they tend to take a set in that position, never to fit well again!
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
