Date & Time resetting to y2000 after the car is turned off
brian307cc2004
New User
Unread post by brian307cc2004 »
Hi. I have a 307 cc 2004 model. The car always starts first time and runs really well. However, recently after the car has been turned off. when I restart the Date & Time display is flashing and has gone back to the year 2000. I can adjust the date and time back to correct settings. but as soon as I turn off the ignition and restart it needs resetting again. Has anybody else had this problem, and do you know how to fix it, Many thanks Brian
spider
x 77
Re: Date & Time resetting to y2000 after the car is turned off
Unread post by spider »
Do you have an aftermarket radio fitted ?
You could check (pull the display panel out) that there is a permanent 12v supply here. There should (from memory) be a 12v 'ignition/accesssory' supply (only present when key is in or turned) and a permanent 12v supply too.
Andy.
brian307cc2004
New User
Hi Spider,
thanks for your reply. I don't have an after market anything, all the bits are standard and I have had the car 11 years now. However your suggestion sounds really good, I will get that checked out. Thanks again.
Brian
x 1995
Unread post by Stickyfinger »
Check ALL of the fuses are the correct rate and they all are fitted as per the book......has the shunt fuse been moved ?
