C5 tailgate that can't keep it up
wurlycorner
x 271
Unread post by wurlycorner »
Common problem.
I'm now (-expletive removed-) off to the back teeth with being hit on the back while rummaging in the boot. :evil: :x :grr: :taz: :gt: :mecker:
The prop isn't that expensive (£68 incl. VAT)
Haynes avoids the job because they're too scared to touch the headlining :roll: Headlining removal doesn't look any more difficult than any other car I've worked on, going on the parts diagram.
Has anyone done the job of replacing the ram?
Difficult?
How far did you have to go along the headlining to gain the access you need?
Any tips/things I will need that I might not think of before starting dismantling?
How is the strut actually attached at each end?
Does the glass strut literally only work on the glass, or do they both come into play for holding the tailgate open? (i.e. do I need to replace both, or just the tailgate one)?
Iain
CX DTR T2 Safari (silver)
electronmirror
x 30
Re: C5 tailgate that can't keep it up
Unread post by electronmirror »
I can't help with the fitting details but have you checked this company for gas struts? http://www.sgs-engineering.com/
Several forum members have reported friendly/knowledgeable service and much cheaper than main dealers for a good quality strut.
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
x 1504
Don't know about whether both are required, but given the hassle of getting to them, I'd replace all 4!!
No idea about the headlining, although I think it was discussed before, and ISTR that it was possible without a full removal....
x 1504
wurlycorner
x 271
8-)
Doesn't sound so bad then :-D
4 bloody struts though :roll:
Plus I will have to stop being lazy and attend to the rear glass not opening as well :roll: :roll:
And well done on the link to cheaper struts 8-) 8-)
Thanks.
It might take me a little while to get round to it, but it's on the 'to do' list now (moved from the 'too difficult' list and slightly higher priority than the 'when I get round to it' list)...
Iain
x 3298
It is possible that the switch for the rear glass lock switch has had water get into it. I had to open mine (to replace the mounting plate, as some prat had epoxied it, locking the wiper spindle!), and I found that when I nipped the switch off and striped the wires back, one was blacked through water damage. Cleaned the wires up, and the glass then opened. Unfortunately the replacement weird lump of plastic (with switch incorporated; you cannot buy them separately) was about £40! Stock code 6405 K3 (and was available within the last 6 months).
x 1240
Unread post by Peter.N. »
The last time I checked I couldn't find anyone with the correct struts so have a suitable length broom handle in the back. If you see anyone offering estate struts double check that they are.
