Which power steering fluid HELP!!!!!
Jerome3
Unread post by Jerome3 »
Hi my 11 c5 vtr+nav is in need of some power steering fluid, as it's not hydractive does it just take ordinary fluid thanx in advance
HDI
x 7
Re: Which power steering fluid HELP!!!!!
Unread post by HDI »
If it's not hydraulic suspension then it will be PS fluid. For confirmation of the correct type just go on one the parts suppliers sites, like Euro car parts, enter you reg and select power steering fluid in the search.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 3566
HDI wrote:If it's not hydraulic suspension then it will be PS fluid. For confirmation of the correct type just go on one the parts suppliers sites, like Euro car parts, enter you reg and select power steering fluid in the search.
Whoa there !!!!!
I'm away from my computer at the moment, but my 2009 C5 on metal suspension takes Total Fluide DA in the PS system, those on hydractive take Total LDS. I think the two fluids are actually the same...... although they're not priced the same !
I can't imagine your 2011 C5 is any different. If your car unexpectedly needs PS fluid then check for a leak on the steering rack.
HDI
x 7
I did say check on eurocarparts ;)
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 1987
Unread post by Stickyfinger »
PSA Specs
PSA S71 2710 .............................................................Total LDS
PSA S71 2710 MAN 3289 Renault PSF Class 1.................Total Flude D
As said, you need to check first for a steel sprung car.
wurlycorner
x 271
Unread post by wurlycorner »
Or you could just look in the handbook that came with the car??? (Assuming it did come with one!)
Iain
CX DTR T2 Safari (silver)
x 1987
Yeh....it may be lost in the cavernous glove box :)
x 5651
Or under one of the front seats.
Took me ages to find those drawers.
x 3566
The steel sprung and Hydractive cars can have the same pump fitted and do have the same steering racks fitted, so I'm guessing it's a safe bet the LDS can be used on steel sprung PS systems.
ECP don't list any PS fluids for my steel sprung C5.
