Citroen AX blower conversion
jsp
x 12
Unread post by jsp »
Hi, I have a Citroen AX spare blower that only works on full speed.
I have copied this picture as I have seen that a Xantia blower resistance easier to fix and cheaper.
I have wired a bit up but, don't exactly know which wire is speed 1 and 2
where does these pins/wires do and go?
Picture from this topic
http://www.frenchcarforum.co.uk/forum/v ... 8&start=15
Many thanks.
x 1452
Re: Citroen AX blower conversion
Unread post by xantia_v6 »
Does your AX have climate control? The Xantia part you have shown is controlled by the climate control ECU, and will not easily work if yours is a simple system with 2 or 3 fixed speeds.
Simple resistor controlled systems, such as used on non-AC Xantia, (and probably the AX) always had the resistor mounted in the airflow of the ventilator box, to keep them cool.
jsp
x 12
Hi, thanks for your reply. The blower came from a Saxo with airco but, the resistance blew up.
It's a small white block mounted on the blower itself.
x 1452
Does the car which is being repaired have an ECU controlling the blower, or just a manual switch?
jsp
x 12
sorry for the late reply, it's a manual switch.
x 1452
The obvious answer is to get a resistor pack from a car with simple switched fan. In theory you could arrange a chain of small resistors to drive the electronic fan controller that you have acquired, but you would need to experiment to find the right values.
