2009 C5 relay clicking
Rob81
Unread post by Rob81 »
Hello. This is my first post for a while - after a couple of years in dull but very reliable Xsara Picassos, I bought a 2.2 C5 Tourer in February. I love it and over the last 20k miles, it's been great on the whole (if a little thirsty) but started to behave a bit oddly earlier this week.
When I go over bumps, what sounds like a relay clicks under the dashboard. When on smooth roads or stationary, there is no noise. I have tried to identify where the noise is coming from and think it's somewhere under the stereo/centre console. I have tried switching off various electrical equipment to see if it's associated with the heater/recirculation/stereo etc but nothing seems to make any difference.
Can anybody give me any pointers or advice? I assume it's some sort of loose or failing relay and that it might cause a problem at some point. I am worried in case it's going to involve enormous expense to track down.
Best wishes
Rob
Citroen C5 2.2 HDi Exclusive Tourer
Peugeot Boxer 2.8 HDi Camper (conversation)
Previously;
Lots of Citroens including 2CVs, Dyane, Acadiane, Bx, Activa, XM CX and Picasso
x 6961
Re: 2009 C5 relay clicking
Rob, dare I say, there are a myriad of relays and ECUs all over the vehicle covering every electrical component, so it will be impossible to guess and unwise to do so. I would suggest that if you are concerned enough to either look at the list of members with a Lexia / Diagbox kit near to you who may be able to help, or if not, a diagnostic session with your local dealer. Whether your dealer will charge you is pot luck - some will charge for a diagnostic session, some will offer this for free - it really is luck of the draw and how well you know them as to whether they will charge you. This is why a lot of members buy their own kits for about £100 (for a decent one), which can be just over the cost of a diagnostic session.
Here is the list of members able to provide diagnostic support:
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178
Rob81
Thanks for the swift response. I have a very good specialist locally. I'll get it booked in. I have visions of it catching fire or something!
Previously;
SaabC5
Unread post by SaabC5 »
Might be worth getting the lower dash panel off and just wiggling/pushing any relays you can find, it may have just worked loose and is moving when you hit a speed bump.
x 1983
Unread post by Stickyfinger »
or
a leaf ?
x 6961
What are you like! :-D
x 1983
should of said..........a leaf .....in the fan.
from what I have seen there are no relays in there ?
Rob81
No leaves as far as I can ;)
I have poke around under the dash in the morning - I tried earlier after but hadn't counted on the hot heating plumbing...!
Thanks again for the replies
Previously;
x 1983
Maybe you can see more by popping out the radio ?
Rob81
Thanks for the advice so far. I have ordered keys to remove the radio and will pop it out when they arrive (tomorrow hopefully). Meanwhile, while routing around under the glove box yesterday, this item dropped out;
https://flic.kr/p/AB9ASw
https://flic.kr/p/AB9zoQ
Any idea what it is?!
(I hope the links work - im writing on my phone)
Thanks,
Rob
Previously;
x 6961
Hi Rob
Here is a diagram of the offending item - it's a 'Cubby Brake Roller', Part 8226 PQ. I believe this is the mechanical / hydraulic stay mechanism for the glove box. It is item 4 on the diagram.
Hope this helps.
Rob81
Perfect. Thanks very much
Previously;
SaabC5
Nowt behind the radio, i've had mine out to replace with an aftermarket unit. Sounds so much better with a decent head unit.
x 1983
As said, there are no relays in there................
Rob81
Having looked at the diagram posted above, I'm going to take the glovebox out tomorrow and have a look behind there.
Previously;
