2009 C5 relay clicking
Rob81
Hello. This is my first post for a while - after a couple of years in dull but very reliable Xsara Picassos, I bought a 2.2 C5 Tourer in February. I love it and over the last 20k miles, it's been great on the whole (if a little thirsty) but started to behave a bit oddly earlier this week.
When I go over bumps, what sounds like a relay clicks under the dashboard. When on smooth roads or stationary, there is no noise. I have tried to identify where the noise is coming from and think it's somewhere under the stereo/centre console. I have tried switching off various electrical equipment to see if it's associated with the heater/recirculation/stereo etc but nothing seems to make any difference.
Can anybody give me any pointers or advice? I assume it's some sort of loose or failing relay and that it might cause a problem at some point. I am worried in case it's going to involve enormous expense to track down.
Best wishes
Rob
Best wishes
Rob
Citroen C5 2.2 HDi Exclusive Tourer
Peugeot Boxer 2.8 HDi Camper (conversation)
Previously;
Lots of Citroens including 2CVs, Dyane, Acadiane, Bx, Activa, XM CX and Picasso
Previously;
- x 6954
Re: 2009 C5 relay clicking
Rob, dare I say, there are a myriad of relays and ECUs all over the vehicle covering every electrical component, so it will be impossible to guess and unwise to do so. I would suggest that if you are concerned enough to either look at the list of members with a Lexia / Diagbox kit near to you who may be able to help, or if not, a diagnostic session with your local dealer. Whether your dealer will charge you is pot luck - some will charge for a diagnostic session, some will offer this for free - it really is luck of the draw and how well you know them as to whether they will charge you. This is why a lot of members buy their own kits for about £100 (for a decent one), which can be just over the cost of a diagnostic session.
Here is the list of members able to provide diagnostic support:
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178
Rob81
Thanks for the swift response. I have a very good specialist locally. I'll get it booked in. I have visions of it catching fire or something!
Previously;
Previously;
SaabC5
Might be worth getting the lower dash panel off and just wiggling/pushing any relays you can find, it may have just worked loose and is moving when you hit a speed bump.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
- x 1983
- x 6954
What are you like!
- x 1983
should of said..........a leaf .....in the fan.
from what I have seen there are no relays in there ?
Rob81
No leaves as far as I can
I have poke around under the dash in the morning - I tried earlier after but hadn't counted on the hot heating plumbing...!
Thanks again for the replies
Previously;
Previously;
- x 1983
Maybe you can see more by popping out the radio ?
Rob81
Thanks for the advice so far. I have ordered keys to remove the radio and will pop it out when they arrive (tomorrow hopefully). Meanwhile, while routing around under the glove box yesterday, this item dropped out;
https://flic.kr/p/AB9ASw
https://flic.kr/p/AB9zoQ
Any idea what it is?!
(I hope the links work - im writing on my phone)
Thanks,
Rob
Thanks,
Rob
Previously;
Previously;
- x 6954
Hi Rob
Here is a diagram of the offending item - it's a 'Cubby Brake Roller', Part 8226 PQ. I believe this is the mechanical / hydraulic stay mechanism for the glove box. It is item 4 on the diagram.
Hope this helps.
Hope this helps.
Rob81
Perfect. Thanks very much
Previously;
Previously;
SaabC5
Nowt behind the radio, i've had mine out to replace with an aftermarket unit. Sounds so much better with a decent head unit.
- x 1983
As said, there are no relays in there................
Rob81
Having looked at the diagram posted above, I'm going to take the glovebox out tomorrow and have a look behind there.
Previously;
Previously;
