xsara 1.6 picasso,desire
tonymike
Unread post by tonymike »
Hi,How easy,or dificult is it to change front wheel bearing?and will I need any special tools or pullers? bearing in mind this old git is 80.thaks in addvance :rofl2:
superloopy
x 19
Re: xsara 1.6 picasso,desire
Unread post by superloopy »
Zimmer maybe [emoji1]
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
tonymike
Zimmer frame, good sence of humor.
x 1489
You will need a puller (and strong arms!) or a hydraulic press. You will also need a 35mm socket and long breaker bar to get the hub nut undone; and removing the hub from the car may not be that easy, and getting the circlip out requires patience and hard work. With deference to your age, I'd entrust it to a garage - make sure that they fit an SKF or SNR bearing though (not a £10 chinese one) - or you will have to do it again next year!
superloopy
x 19
Re: RE: Re: xsara 1.6 picasso,desire
tonymike wrote:Zimmer frame, good sence of humor.
Sorry ... but had you not of mentioned your age [emoji1] Just couldnt resist ....
Mike
tonymike
Picasso rear view mirror, how do I get the( fitting that looks as if it is bonded to the screen off??) and how is a new fitting bonded,is it wieh a type of super glue?,any info would be acted upon,thank you in advance.tonymike
