xsara 1.6 picasso,desire
tonymike
Hi,How easy,or dificult is it to change front wheel bearing?and will I need any special tools or pullers? bearing in mind this old git is 80.thaks in addvance
superloopy
- x 19
Re: xsara 1.6 picasso,desire
Zimmer maybe [emoji1]
Sent from my LG-D855 using Tapatalk
Mike
tonymike
Zimmer frame, good sence of humor.
- x 1496
You will need a puller (and strong arms!) or a hydraulic press. You will also need a 35mm socket and long breaker bar to get the hub nut undone; and removing the hub from the car may not be that easy, and getting the circlip out requires patience and hard work. With deference to your age, I'd entrust it to a garage - make sure that they fit an SKF or SNR bearing though (not a £10 chinese one) - or you will have to do it again next year!
superloopy
- x 19
Re: RE: Re: xsara 1.6 picasso,desire
Sorry ... but had you not of mentioned your age [emoji1] Just couldnt resist ....tonymike wrote:Zimmer frame, good sence of humor.
Mike
tonymike
Picasso rear view mirror, how do I get the( fitting that looks as if it is bonded to the screen off??) and how is a new fitting bonded,is it wieh a type of super glue?,any info would be acted upon,thank you in advance.tonymike
