Xantia brake pipe woes
Stewart(oily)
x 35
Unread post by Stewart(oily) »
The saga continues, trying to keep my mates Xantia S1 on the road, brake pipe flexibles need replacing, unions siezed, steel pipe wasted to nothing where they join, it snapped :evil: even after gentleness, heat and plusgas were all anointed in the prescribed manner, can anyone confirm that this pipe is indeed 4.5mm diameter ? and is there a link to a suitable diagram of the brake pipes, I suppose my chances of finding an offside pipe are slim to bugger all.
Also, where the steel pipe meets the flexi, is that a normal brake pipe flare ? I have a cunning plan where a compression fitting is involved :twisted:
x 7163
Re: Xantia brake pipe woes
You could try this sticky here started by Kenny W. I made my little contribution with a bit of diagram of the Xantia S1 non-sinker back end about three or four posts down. I think there are a few diagrams from service citroen posted up too.
http://www.frenchcarforum.co.uk/forum/v ... =3&t=48254
KennyW
x 163
Unread post by KennyW »
Stewart(oily),
There are not 4.5mm but 4.76mm or 3/16" piping with a bubble type flare and 10mm x1.00mm thread. I've just some pipes but not fitted to car yet.
How urgent is this?
They are a flare popular on merc's but they used on the biggar citroen pipes hp hydraulic pump and pressure regulator. It's called F 180 look at this site www.beepro.de who have a tool which makes them all.
Kenny
C3 1.4 petrol (SWMBO)
Stewart(oily)
x 35
Looking at Maclolm Lockwoods web catalogue http://mlockwood.org.uk/ I will call him tomorrow, I reckon he has what I need.
KennyW
x 163
FYI
part no 488671 4.75mm L 924mm still available cost £12.96
part no 4886F6 4.75mm L 1774mm NFP
Ignore the above,that's for my version. It appears most of the pipes are NFP. But worth acheck for your variant
kenny
x 8309
Pleiades will always be able to offer advice and a solution...
lexi
x 134
Unread post by lexi »
I have checked all the parts catalogues. You are out of luck. There are no woes listed for your brake pipes
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 8309
lexi wrote:I have checked all the parts catalogues. You are out of luck. There are no woes listed for your brake pipes
Oh woe is me :lol: :lol:
Stewart(oily)
x 35
Thanks for the replies, Kenny especially :) knowing that its an imperial pipe makes a lot of difference.
My woes may yet be eased 8-)
KennyW
x 163
Stewart,
I have got a pipe with a normal bubble flare ont it and the right male ends which I've tested on new front flexible hoses and the fit is fine.
I will not know if it seals correctly until on the car. The weather is awful so it won't be happening soon.
Kenny
x 8309
Kenny, is it standard 'bubble' flares at both ends of the pipe? I assume the other end goes straight to the ABS block. Is this correct?
KennyW
x 163
Jim,
Yes my pipe goes direct to the abs but it is not the standard bubble flares. It's a half a bubble flare with a flat (180 degree) face at pipe end. I'm going to try the standard bubble flare but I don't know if it will seal. It's an experiment and it will be easier if it works to get the pipes.
If you look at www.beepro.de site they make a hand held brake tool which makes all flares including the early c5 flare.
As you suggested in another thread invest i a tool and I think it will be this one.
Kenny
x 8309
Excellent Kenny, I'll be looking forward to hearing the results of your tests... Fingers crossed for complete success....
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Ive got recovered brake pipes in the shed .. I recovered a few off cars that went.. nothing was left on them... if nothing comes up for you..
A very sad...
1994 XM 2.1 d auto
