Also, where the steel pipe meets the flexi, is that a normal brake pipe flare ? I have a cunning plan where a compression fitting is involved
Xantia brake pipe woes
Stewart(oily)
- x 35
The saga continues, trying to keep my mates Xantia S1 on the road, brake pipe flexibles need replacing, unions siezed, steel pipe wasted to nothing where they join, it snapped
even after gentleness, heat and plusgas were all anointed in the prescribed manner, can anyone confirm that this pipe is indeed 4.5mm diameter ? and is there a link to a suitable diagram of the brake pipes, I suppose my chances of finding an offside pipe are slim to bugger all.
- x 7163
Re: Xantia brake pipe woes
You could try this sticky here started by Kenny W. I made my little contribution with a bit of diagram of the Xantia S1 non-sinker back end about three or four posts down. I think there are a few diagrams from service citroen posted up too.
http://www.frenchcarforum.co.uk/forum/v ... =3&t=48254
KennyW
- x 164
Stewart(oily),
There are not 4.5mm but 4.76mm or 3/16" piping with a bubble type flare and 10mm x1.00mm thread. I've just some pipes but not fitted to car yet.
How urgent is this?
They are a flare popular on merc's but they used on the biggar citroen pipes hp hydraulic pump and pressure regulator. It's called F 180 look at this site www.beepro.de who have a tool which makes them all.
Kenny
How urgent is this?
Kenny
C3 1.4 petrol (SWMBO)
Stewart(oily)
- x 35
Looking at Maclolm Lockwoods web catalogue http://mlockwood.org.uk/ I will call him tomorrow, I reckon he has what I need.
KennyW
- x 164
FYI
part no 488671 4.75mm L 924mm still available cost £12.96
part no 4886F6 4.75mm L 1774mm NFP
Ignore the above,that's for my version. It appears most of the pipes are NFP. But worth acheck for your variant
kenny
kenny
- x 8309
Pleiades will always be able to offer advice and a solution...
lexi
- x 134
I have checked all the parts catalogues. You are out of luck. There are no woes listed for your brake pipes
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 8309
Oh woe is melexi wrote:I have checked all the parts catalogues. You are out of luck. There are no woes listed for your brake pipes
Stewart(oily)
- x 35
Thanks for the replies, Kenny especially
knowing that its an imperial pipe makes a lot of difference.
My woes may yet be eased
KennyW
- x 164
Stewart,
I have got a pipe with a normal bubble flare ont it and the right male ends which I've tested on new front flexible hoses and the fit is fine.
I will not know if it seals correctly until on the car. The weather is awful so it won't be happening soon.
Kenny
Kenny
- x 8309
Kenny, is it standard 'bubble' flares at both ends of the pipe? I assume the other end goes straight to the ABS block. Is this correct?
KennyW
- x 164
Jim,
Yes my pipe goes direct to the abs but it is not the standard bubble flares. It's a half a bubble flare with a flat (180 degree) face at pipe end. I'm going to try the standard bubble flare but I don't know if it will seal. It's an experiment and it will be easier if it works to get the pipes.
If you look at www.beepro.de site they make a hand held brake tool which makes all flares including the early c5 flare.
As you suggested in another thread invest i a tool and I think it will be this one.
Kenny
Kenny
- x 8309
Excellent Kenny, I'll be looking forward to hearing the results of your tests... Fingers crossed for complete success....
citroenxm
- Fallen Hero
- x 70
Ive got recovered brake pipes in the shed .. I recovered a few off cars that went.. nothing was left on them... if nothing comes up for you..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
