Piping between injectors
superloopy
x 19
Unread post by superloopy »
Not sure what the exact term is for the little pipes which run between the injectors on a turbodiesel? I'm about to replace the glowplugs and now seems a good time to replace these little black pipes but with what? Anyone know the citroen part numbers for the piping and the little end pipe?
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
exect
Re: Piping between injectors
Unread post by exect »
They are called leak off pipes and can be bought in almost any car accessory shop as a kit or pipe by the metre.
elma
x 284
Unread post by elma »
The end is included in the set. Try to get a length as the longer bit from number 4 injector won't be included with precut lengths.
x 8408
Watch those ends as they are often the first to split... I still favour making an end from a bit of spare pipe doubled-back on itself and held tight with a couple of cable ties...
