Piping between injectors
superloopy
- x 19
Not sure what the exact term is for the little pipes which run between the injectors on a turbodiesel? I'm about to replace the glowplugs and now seems a good time to replace these little black pipes but with what? Anyone know the citroen part numbers for the piping and the little end pipe?
Mike
exect
Re: Piping between injectors
They are called leak off pipes and can be bought in almost any car accessory shop as a kit or pipe by the metre.
elma
- x 284
The end is included in the set. Try to get a length as the longer bit from number 4 injector won't be included with precut lengths.
- x 8417
Watch those ends as they are often the first to split... I still favour making an end from a bit of spare pipe doubled-back on itself and held tight with a couple of cable ties...
