Quick Xantia airbag Q
Stewart(oily)
x 35
Unread post by Stewart(oily) »
If I replace the failed component, ie the seatbelt pretensioner, will the bloody light go out on its own ? or will the fault need to be cleared using electrickery ? TIA
x 3298
Re: Quick Xantia airbag Q
When I replaced the faulty side airbag ECU the next time I started the Xantia the light went out after the normal test period.
Stewart(oily)
x 35
Thank you, Onward to success :)
x 1502
Are you sure it's the pre-tensioner, they don't usually give trouble....
