Quick Xantia airbag Q
Stewart(oily)
- x 35
If I replace the failed component, ie the seatbelt pretensioner, will the bloody light go out on its own ? or will the fault need to be cleared using electrickery ? TIA
- x 3296
Re: Quick Xantia airbag Q
When I replaced the faulty side airbag ECU the next time I started the Xantia the light went out after the normal test period.
Stewart(oily)
- x 35
Thank you, Onward to success
- x 1488
Are you sure it's the pre-tensioner, they don't usually give trouble....
