SO....I fixed the fan with a replacement, refitted the bumper etc........so what next ?
Well the rear screen washer has packed up today...Pipe broken from car to tailgate, not the wires but the water, broken right on the entry point so not easy to fix so I will have to strip the trim and replace the whole section. (Good choice, hard (ish) plastic pipe that goes brittle...... Good Job Citroen)
Also, Near side wheel valve has started to leak, transponder type, I noticed it when I washed the car
Tips for removing the tail gate trim ?
I do wonder if I will get thru at least ONE fracking week without something breaking/falling-off this bloody car
Never ending C5x7 problems
- x 1999
- x 3566
Re: Never ending C5x7 problems
I lose track of who runs DocBackup, but if you haven't got it, details for the tailgate trim should be here:
http://www.filedropper.com/c5x7-c4bs010 ... ngtailgate" onclick="window.open(this.href);return false;
- x 1999
ta MUCHLY, that will sort me.
So, whats next ?.....aggg
- x 3566
Whatever goes wrong next, this should cure it.....Stickyfinger wrote:So, whats next ?.....aggg
DickieG
- Monaco's youngest playboy
- x 38
Citroen sell the relevant section of pipe as a separate plug and play item, so no need to delve onto the tailgate fishing pipes through etc.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 1999
Wish I had got a British built one......these little Yank bombs would not worry me !
http://thebrigade.com/2011/07/19/centur ... 17-photos/
What Dicky ? you say I do not have to take the panels off ?
I will be ordering the tail gate pipe section from Avalon Citroen .....is it that one you speak of ?
vborovic
- Locked user account
- x 40
My rubber pipe repair failed (it split), so I'm doing the same repair as you ... luckily I don't use the rear washer these days, so it can wait a bitStickyfinger wrote:Well the rear screen washer has packed up today...Pipe broken from car to tailgate, not the wires but the water, broken right on the entry point so not easy to fix so I will have to strip the trim and replace the whole section. (Good choice, hard (ish) plastic pipe that goes brittle...... Good Job Citroen)
wurlycorner
- x 271
Still, the current boss of PSA says the way to future survival is to use ever increasing quantities of cheap crap to build their cars - so just imagine how much worse things could be?
Iain
CX DTR T2 Safari (silver)
Iain
- x 1999
Rock ON.....I'm off to buy a Morris Marina and enjoy the build quality
I am beginning to think I should sell this pile of poo and make me a V6 Xantia Activa Estate.............ummmm
- x 1485
Looks like it might be this bit:
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00006439J4 WDW WASHER PIPE 7.18 GBP 8.62 GBP 8.62 GBP
OnlineHell Razor5543
- x 3304
This would worry me a little bit more than that USA fire cracker!;Stickyfinger wrote:Wish I had got a British built one......these little Yank bombs would not worry me !
http://thebrigade.com/2015/07/09/russia ... and-story/" onclick="window.open(this.href);return false;
old'uns
- x 127
it's an X7.....expect the worstStickyfinger wrote:ta MUCHLY, that will sort me.
mine potentially will/may need a new front strut or the source of the LDS leak sorting, the paper/plastic/ whatever in the blower heater removing...think lollipop stick and bicycle wheels
Aircon sorting, had a regas last year so i'm bracing myself for condensor/pipes etc
the DPF cleaned out, i'm convinced the Eolys isn't being injected? i may take up SaabC5's idea and dose the tank manually
Alternator sounds a bit 'growly' first thing at tickover or maybe its the AC compressor or the Pulley/tensioner
I honestly reads that that lot back and thought..'Autotrader here we come..'
black flexi pipe has been done on mine as well as the leaky LED 3rd lamp pin connectors sorted...water from washer pipe running through the cracked plastic doesn't help
replaced mine from washer jet, through the spoiler, through the body grommet with standard clear plastic pipe..4mm i think?
just inside the body is the 1 way valve connector, you can just reach if you pull seal away from lining and remove the hanging bracket, the pipe runs down from there and there is enough play to pull out to attach pipe
i do now remember why i probably won't get shut......500 miles on m'way, armchair comfort, 45mpg from a 170 bhp slush box and can still walk after getting out.
plus the fact OH likes the auto electric handbrake...handy when she has use of right arm only
- x 1999
13
6439 J4
WINDOW WASHER PIPE
- REAR SCREEN WIPER
14
6439 J5
WINDOW WASHER PIPE
- REAR SCREEN WIPER
But I think I will make some up (as noted above...cheers oldUns) as the Citroen plastic is a very stupid choice of material, brittle after 5 years...LOL ROLF Fart Giggle Sigh
6439 J4
WINDOW WASHER PIPE
- REAR SCREEN WIPER
14
6439 J5
WINDOW WASHER PIPE
- REAR SCREEN WIPER
