Wanted: Air intake rubber hose..
DS21
Unread post by DS21 »
Hi folks,
On my Activa, Series 1 2.0. 8V turbo, the Air intake rubber hose (goes between the plastic air cleaner housing and the metal air intake pipe) is split where the bellows are.
Does anyone have a good one for sale please and even better if you're coming to Peterbrorough for the National.. :)
Thanks,
George
x 8378
Re: Wanted: Air intake rubber hose..
Hi George, you can have mine after I've done the V6 conversion :wink:
You may have a bit of a wait though as the project is progressing very slowly :(
x 2000
Unread post by Stickyfinger »
Just checked my donor car, stored next door, it has a split in it...sorry
x 8378
Stickyfinger wrote:Just checked my donor car, stored next door, it has a split in it...sorry
Most have now... Finding a good one is not easy at all...
The V6 ones suffer in a similar way too.. Duct tape does a fair repair although it needs redoing on a regular basis...
x 2000
Seems so, that's both the V6.Activa (swapped for the V6 Green-Goblin one), and the donor Activa both shot....1 out of 3 :)
DS21
Thanks guys I really appreciate you helping me out.
Alasdair, thanks for checking, by the way I missed you at the CCC National, I went on the Sunday.
Jim, I am happy to wait for when you are ready, thank you.
x 2000
ep....sorry I missed you.....its was errrr...very "low key" with a "select number" of cars...
Are UK National events often like that ?
DS21
It was a bit empty on the Sunday too and then got better later in the day... Shame not much representation for the Xantia, quite a few BXs turned up and DS and a contingent of C6s, amongst others...... And not to mention a few very nice GSs...
x 8378
Shame that, about the National... Weather might have put some off perhaps...
I'm wondering if those hoses (both TCT and V6) should be added to the list?
KP
x 27
Unread post by KP »
The bellows are the reason they fail as that after a good few years of hot and cold cycles and engine bay dust dirt and road dirt flicked up from not having an undertray the rubber gets dried out. Inevitably the only way to get around the issue is to get a silicone one made up with bellows on it. The bellows are critical as they allow for the twisting motion of the engine to not pull the airbox from its mounts or stress that inlet pipe. This is often why the ductape and other methods fail. Another much cheaper option is to use some of the cold air feed pipe thats often available from motor tuning shops and ebay. it flexes to the angles that you need and just needs clamping down around the metal turbo inlet pipe which in itself is an odd shape like a squashed egg really.
I'm looking to measure the circumference of both ends to see if there is already a suitable silicone hose out there as mine is starting to split and even ones i have been able to be found from breakers in europe are the same so not worth buying.
Theres a dealer in spain who has the last one stocked and am just waiting for them to get back to me about shipping before i get it and use it as a template. It was also used in the 406 SRi Turbo but they are even fewer in numbers than the xantia turbo.
I have two good intact and unbroken v6 pipes but they are far too short and wide to even consider using, shame as well as they are in great nick :(
x 8378
If you have good V6 pipes Will then V6 owners may like them as they too are getting scarce... There is no way they can be used on a TCT.
One hose that may work in a time of need is one from a 1.9TD. They are vaguely similar but I'm not sure just how now...
x 2000
I would "book" one if they are for sale, I like shelf spares like that.....however if another v6 owner has an immediate need I would understand.
KP
x 27
Unread post by KP »
The 1.9td hose doesn't work im afraid Jim :( the metal rear pipe thats the turbo inlet is too large for it as the 1.9td is probably about 2/3 the circumference of it :(
Yes i've got 2 V6 ones and air boxes and bits kicking around im sure in the garage and bits off the broken V6 as well.
Drop us a PM of what you fancy, although knowing you, you'll just want it all your greedy hoarder :D
KP
x 27
Unread post by KP »
Sticky if Jim has one and is happy to let you have the other thats ok for me :)
Same goes if either of you have a spare TCT hose :D
x 8378
KP wrote:Sticky if Jim has one and is happy to let you have the other thats ok for me :)
That's perfect by me :-D
KP wrote:Same goes if either of you have a spare TCT hose :D
I will have but not just yet...
