STOP light
noxati11
STOP light
Unread post by noxati11 »
Hey, on my Xantia started flashing STOP light with water temperature. But gauge is in normal position. "Physically" is temperature in normal, I checked that. My X1 does not have any type of float for water amount. Even so, the radiator is full. I changed all temperature sensors. But still appears randomly. Flashing or for few seconds still. Is it maybe some problem on PCB of instruments? :(
Thanks for respond.
Xantia 2.0 16V 112kW
Xantia V6 Activa
x 3303
Re: STOP light
If you have air conditioning, and one (or both) of the cooling fans fails to kick in that can cause the error described. On my previous car this would sometimes happen, and turning the A/C on and off a few times cleared it. If this doesn't work you may need to check the fans or the control relays, in the area at the top of the fan assembly.
Mandrake
x 695
Re: STOP light
Unread post by Mandrake »
If you've changed all (!) the coolant temperature sensors it's probably the bitron relay under the left hand headlight - try giving the contacts on the connector to the relay a good clean. Quite a common problem.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
noxati11
Re: STOP light
Thanks for reply, but what you writing I've already done :(. Changed fan, sensors, relay, cleaned contacts from oxidation, flushed coolant and still it appears :cry:
btw i don't have air condition.
Xantia V6 Activa
Estately
x 22
Re: STOP light
Unread post by Estately »
Our 2000 2.0l HDi 90 Xantia with climate control started giving a similar warning from time to time until it became more consistent.
It is fitted with a low water level indicator and once replaced the warning stopped.
I did test the replacement by connecting and not dropping it into the header tank - when the warning lights came on.
Hope that helps.
Andy.
If it can happen it will.
