Hi all I have got a problem with my 2005 xsara picasso 2.0 hdi
On start up and shut down I got a nocking noise I have looked over the car and I think the noise is comeing from the rear engine mount but the rubber looks new could this b the drive shaft
Nocking noise on start up
- x 1240
Re: Nocking noise on start up
You need to be able to look underneath as someone else starts/stops it. It could be the exhaust touching the body somewhere.
Sloppysod
- x 396
Does the knocking noise disappear when you depress the clutch, if so DMF?
Sent from my SM-N910F using Tapatalk
Stu
elma
- x 284
The driveshaft does have a centre bearing that can cause knocking when worn. From what you have said I'm not sure thats your cars issue though. Mine have resulted in a knocking under acceleration and a wobbly gearstick when they've let go.
Edit, sorry I read Xantia not Xsara, so what I said is probably not relavent.
Leon.cassie
The noise is there when u change gear ie clutch in nock then cluch out nock and if costing in gear nock nock nock
Just been under the car and i think there is a clicking noise from the drive shaft where it passes in the engine mount could this be the problem
Leon.cassie
Sorry dmf?Sloppysod wrote:Does the knocking noise disappear when you depress the clutch, if so DMF?
elma
- x 284
Dual mass flywheel
Leon.cassie
Ok sorry no its still there sometimes when clutch is downelma wrote:Dual mass flywheel
SwissSPEC
Does it sound a bit like a pumping type sound? If it does, then its probably the (camshaft i think) pulley, the one which has the internal bearings which wear out & then it starts to oscillate which causes that sound.
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
Bx Gti 16v
BX TZD Turbo - Sorn
Leon.cassie
No pumping sound just like a loud clicking
elma
- x 284
I think your drive shaft centre bearing is worn out.Leon.cassie wrote: Just been under the car and i think there is a clicking noise from the drive shaft where it passes in the engine mount could this be the problem
Leon.cassie
Thanks to all the help found the problem rear engine mount (gave way on the way home) not a way fix to replace just the rubber and not the complete thing
Stewart(oily)
- x 35
The rubber is available separately from GSF.
