Nocking noise on start up
Leon.cassie
Unread post by Leon.cassie »
Hi all I have got a problem with my 2005 xsara picasso 2.0 hdi
On start up and shut down I got a nocking noise I have looked over the car and I think the noise is comeing from the rear engine mount but the rubber looks new could this b the drive shaft
x 1240
Re: Nocking noise on start up
Unread post by Peter.N. »
You need to be able to look underneath as someone else starts/stops it. It could be the exhaust touching the body somewhere.
Sloppysod
x 386
Unread post by Sloppysod »
Does the knocking noise disappear when you depress the clutch, if so DMF?
Sent from my SM-N910F using Tapatalk
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
elma
x 287
Unread post by elma »
The driveshaft does have a centre bearing that can cause knocking when worn. From what you have said I'm not sure thats your cars issue though. Mine have resulted in a knocking under acceleration and a wobbly gearstick when they've let go.
Edit, sorry I read Xantia not Xsara, so what I said is probably not relavent.
Leon.cassie
The noise is there when u change gear ie clutch in nock then cluch out nock and if costing in gear nock nock nock
Just been under the car and i think there is a clicking noise from the drive shaft where it passes in the engine mount could this be the problem
Leon.cassie
Sloppysod wrote:Does the knocking noise disappear when you depress the clutch, if so DMF?
Sorry dmf?
elma
x 287
Dual mass flywheel
Leon.cassie
elma wrote:Dual mass flywheel
Ok sorry no its still there sometimes when clutch is down
SwissSPEC
Unread post by SwissSPEC »
Does it sound a bit like a pumping type sound? If it does, then its probably the (camshaft i think) pulley, the one which has the internal bearings which wear out & then it starts to oscillate which causes that sound.
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
Leon.cassie
No pumping sound just like a loud clicking
elma
x 287
Leon.cassie wrote: Just been under the car and i think there is a clicking noise from the drive shaft where it passes in the engine mount could this be the problem
I think your drive shaft centre bearing is worn out.
Leon.cassie
Thanks to all the help found the problem rear engine mount (gave way on the way home) not a way fix to replace just the rubber and not the complete thing
Stewart(oily)
x 35
Unread post by Stewart(oily) »
The rubber is available separately from GSF.
