Can you fit BX/Xantia spheres to a C5?
Has anybody tried it?
I understand Bx/Xantia spheres can be re-gassed?
Cheers
C5 Spheres etc
- x 1996
- x 1240
Re: C5 Spheres etc
They use different hydraulic fluid.
- x 1996
wurlycorner
- x 271
Re: C5 Spheres etc
Don't know if anyone has tried to, but no, you can't/shouldn't.2cvman wrote:Hi,
As others have said the fluid is different and hence the internal components and seals are not compatible.
Although it is possible to re-gas some LHM spheres, that's partly the point... They do leak off over time and so they need to be recharged.
The spheres in a C5 don't (well not to anything like the same degree) so even if you could fit them, it would be a false economy to fit LHM spheres to an LDS car.
Iain
CX DTR T2 Safari (silver)
Iain
2cvman
Re: C5 Spheres etc
Thanks for replies.
Want to run C5 spheres at a lower pressure, but not in a C5.
Anybody taken the "nipple" out of a C5 sphere?
cheers
Thanks for replies.
cheers
wurlycorner
- x 271
Re: C5 Spheres etc
Ah yes, seen your other post now... Adjustable suspension for a 4x4 2cv...
Iain
Iain
