C5 Spheres etc
2cvman
C5 Spheres etc
Unread post by 2cvman »
Hi,
Can you fit BX/Xantia spheres to a C5?
Has anybody tried it?
I understand Bx/Xantia spheres can be re-gassed?
Cheers
x 1997
Re: C5 Spheres etc
Unread post by Stickyfinger »
why would you want to ?
x 1240
Re: C5 Spheres etc
Unread post by Peter.N. »
They use different hydraulic fluid.
x 1997
Re: C5 Spheres etc
yep....LHM and LDS
wurlycorner
x 271
Re: C5 Spheres etc
Unread post by wurlycorner »
2cvman wrote:Hi,
Don't know if anyone has tried to, but no, you can't/shouldn't.
As others have said the fluid is different and hence the internal components and seals are not compatible.
Although it is possible to re-gas some LHM spheres, that's partly the point... They do leak off over time and so they need to be recharged.
The spheres in a C5 don't (well not to anything like the same degree) so even if you could fit them, it would be a false economy to fit LHM spheres to an LDS car.
Iain
CX DTR T2 Safari (silver)
2cvman
Re: C5 Spheres etc
Hi,
Thanks for replies.
Want to run C5 spheres at a lower pressure, but not in a C5.
Anybody taken the "nipple" out of a C5 sphere?
cheers
wurlycorner
x 271
Re: C5 Spheres etc
Ah yes, seen your other post now... Adjustable suspension for a 4x4 2cv...
Iain
