Bleeding V6 Xantia !
x 1996
Unread post by Stickyfinger »
Hi guys
before restarting her I wonder, what is the bleeding procedure on the V6 ?
x 1459
Re: Bleeding V6 Xantia !
Unread post by xantia_v6 »
There are 2 Allen head bleed screws on the engine (near the top and bottom radiator hoses) in addition to the bleed port on the radiator and the heater matrix.
First bleed the radiator, then the 2 on the engine and then the heater.
I usually repeat the sequence after running the engine for about a minute.
x 1996
Cheers.job done...jobs a good'un with zero leaking.
