Hi guys
before restarting her I wonder, what is the bleeding procedure on the V6 ?
Bleeding V6 Xantia !
- x 1996
- x 1466
Re: Bleeding V6 Xantia !
There are 2 Allen head bleed screws on the engine (near the top and bottom radiator hoses) in addition to the bleed port on the radiator and the heater matrix.
First bleed the radiator, then the 2 on the engine and then the heater.
I usually repeat the sequence after running the engine for about a minute.
- x 1996
Cheers.job done...jobs a good'un with zero leaking.
