Coolant loss
x 2007
Coolant loss
Unread post by Stickyfinger »
Great news...coolant leak on the V6Activa....rats !
Had a quick look and its running down the back of the engine, looked at the matrix outlets, new fittings to new plastic so not there it seems. Sticking my flesh into a hot engine \I found no dampness on the expansion tank, BUT there does look like dampness on the Degassing Tank....new is no longer available for Citroen and the one from the V6 looks horrid and ready to blow as well....thoughts on where to get new if poss ?
I take it I go in after removing the Air box and expansion tank...
cheers chappies
x 2007
Re: Coolant loss
Well I let it cool a bit...ouch.... and this is the best view I can get...
This is the view of the degass pot.....and if that goes HOT goes the engine.....damm
x 8448
Re: Coolant loss
To get at it properly Sticky, you are also advised to remove the inlet manifold... It makes the whole job a lot easier...
It's worrying the degassing tanks are now NFP. They do go..
We may need to get creative...
x 2007
Re: Coolant loss
Well this put off the MOT and new V5 test...............rats
In the Army we used....NFC (no ------- chance)
The Cossie brigade use these as they have had cooling gas problems as well..they use this design
Any reason why we cannot use this and an alloy header tank, the ones on the car are very simple.
x 94
Re: Coolant loss
Unread post by citronut »
NFP = NO F***ING PARTS
Regards, malcolm.
x 2007
Re: Coolant loss
ALL of the cooling pipes are NFP, including all the water pump/rad side as well.
At the moment I an looking at building all the down deep stuff (which I need to get to now anyway) back together with silicon tube made up to shape with joiners. It may save me going back down there again.
x 2007
Re: Coolant loss
UPDATE....Pics of the work needed to fix it.
http://www.frenchcarforum.co.uk/forum/v ... &start=210 @ page 15
