Xantia Brake Pads
tim leech
x 12
Xantia Brake Pads
Unread post by tim leech »
Hi Guys
Can anyone confirm what front pads my 1998 S1 2.0 Auto 8v should have, I bought some off eBay from a Citroën dealer (genuine ones) and arranged to have them fitted at my local independent dealer who confirm they are the wrong ones.....although on the box is says all models!
Are they all same for the standard cars like on a BX, and then vented for Activa/V6?
A waste of money on parts and labour. :roll:
1994 XANTIA 1.8i SX 132k, From new,
1985 BX 19GT the beige wonder
x 94
Re: Xantia Brake Pads
Unread post by citronut »
give us the last 8 digits of your last 8 digits of the chassis/VIN No. and i will get you the OE No. and send you your cars birth certificate
Regards, malcolm.
tim leech
x 12
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Later cars have larger discs and caliper carriers.. 1.6 1.8 2.0 8v petrols and D and td, hdi 90 hatchs use one pad.. the v6 and hdi 110s use larger bosch caliper and pads..
Early cars have 266mm discs and later cars P - R reg used 283 discs and larger carrier .. here is where the mistake is made.. i beleve the pad is a bit wider on these but look like the earlier ones..
Estates have always had larger pads of their own size / style different to the hatch ones..
A very sad...
1994 XM 2.1 d auto
tim leech
x 12
The garage said the ones I had are too big.
citroenxm
Fallen Hero
x 70
Got a pic tim??
A very sad...
1994 XM 2.1 d auto
tim leech
x 12
Not right now guys the cars back together
x 1488
VIN's no good Tim. Just need the last 8 digits
x 94
that VIN dont work Tim, av another go #-o :wink:
Regards, malcolm.
