peugeot 806 turbo
m300td
peugeot 806 turbo
Unread post by m300td »
hi if anyone could help me
I have a very battered 806 2,0 hdi gtx (but would not change it!!)
over the last few months the turbo seems to be getting louder
I think I need to change it could anyone tell me if this turbo is the same as fitted to other Peugeot/citroen models
and how easy is it to change
many thanks
malc
lexia owner nr telford
spider
x 77
Re: peugeot 806 turbo
Unread post by spider »
I found the most cause of noise with this was a split boost hose (there's one right at the back underneath) and / or issues with some of the inlet pipework.
Is it really noisy ? It will be the same unit fitted to the 406 and possibly late 306. Bear in mind I think there's at least two manufacturers, and you need to match it up if possible.
It may be a pig to change on an 806 though due to limited space, a H/G is quite annoying on these.
Andy.
m300td
thanks for the information could you tell me what a h/g is ?
malc
x 1490
Head gasket
