Hi there, converted my C5 to manual, i red a lot about that process but in BMW and more exotic cars. For now, all runs great but few small problems, i saw that there is some clutch pedal switch that i am missing. And may be because of that, when i try to switch gears fast, each time i press clutch engine revs jumps up instead of staying on same place or start dropping a bit. My guess is that exactly switch that tells the ecu that i had pressed the clutch pedal.
I looked everywhere near my pedals and there is no such connector female to put the switch.
Can any one help me out and point out where should this switch connect?
I must notice that in lexia all set to manual and i have no faults at all.
Ecu had not been remapped to manual in any way yet ( and i guess i don't have to do that at all)
Converted my c5 hdi 2.0 110bhp from auto to manual, have som
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: Converted my c5 hdi 2.0 110bhp from auto to manual, have
I think the clutch switch is just for the fitment of cruise control and its some other issue causing the over rev
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
I am pretty out of clues because i had a Xsara Hdi manual gear before and the revs fallen faster, like right after i left the gas pedal, i tested few c5 Hdi here and all of them was automatic and all of them behave the same. The has does not fall right after i leave the pedal. This is not a problem It seems more like an automatic car converted to manual.. [emoji12]citroenxm wrote:I think the clutch switch is just for the fitment of cruise control and its some other issue causing the over rev
I want some one to find me a diagram where should i connect the clutch switch to the harness because i have no free plugs around the pedals.
- My Cars: Citroen C5 Tourer 3.0 V6 HDI 240 2009
Pin 21 in the ECU edc15 is for the clutch switch
By the way, is this the same pin that leads to automatic gear pin unlock?hanskj wrote:Pin 21 in the ECU edc15 is for the clutch switch
I dont know, but I think its linked to the brake switch. But you could measure that with a multimeter
Ok, i will.hanskj wrote:I dont know, but I think its linked to the brake switch. But you could measure that with a multimeter
Thank you my friend.
