scrapheap challenge is back
- x 94
scrapheap challenge is back 15/3/15 i think its channel 4
Regards, malcolm.
Zelandeth
- x 1608
Re: scrapheap challenge is back
Ooooh...will have to put that in the calendar.
Hopefully they will have kept it as it was at its best.
Still think one of my favourites was the one and only properly successful speedboat episode - when the camera crew couldn't keep up with it. The looks on the faces of the presenters were classic!
Current fleet:
07 Volvo V70 SE D5, 89 Ford Thunderbird, 85 Sinclair C5, 84 Trabant 601S, 73 AC Model 70, 62 Rover 110.
- x 8444
Ahh and I thought you'd been looking at my driveway again Malcolm
- x 94
you aint sin my back garden then hun,CitroJim wrote:Ahh and I thought you'd been looking at my driveway again Malcolm![]()
it would put any good scrapyard to shame
aren't team WFA entering into the scrapheap challenge then Jim,
they could build a V6 push bike with 3 speed derailleur gears
Regards, malcolm.
- x 8444
We are and our first project is a V6 powered sphere tester....citronut wrote: aren't team WFA entering into the scrapheap challenge then Jim,
they could build a V6 push bike with 3 speed derailleur gears![]()
We do find winding the handle very tiresome
- x 3298
Don't forget the power take off to your kitchen, Jim. Think of all the useful things you can do with it; blender, coffee grinder, food mixer, and so on. Another power take off to run tools in the workshop would also be useful.
- x 8444
And put a generator on the end of it and sell the surplus back to the national grid...
I see a profit in this, especially if the V6 could be made to run on poo as the Bath bus fleet does now...
addo
- Sara Watson's Stalker
- x 95
- x 8444
Re:
That's a very good questionaddo wrote:If you can't snap one off, how do you pay your fare?
The buses in question don't have seats, they have toilets..
Or so the pictures on the sides of the buses would suggest...
Brings a whole new meaning to 'Couldn't give a s**t...'
Zelandeth
- x 1608
Still wish I had photos of the farm buggy I helped some friends build a few years back that was made in true Scrapheap Challenge style. It consisted of the chassis of a dead Land Rover 90 that got rolled, the engine (but no electrics!) From a Jeep Cherokee that got T-boned by a truck and had sat in the corner of the yard, the carbs off a Jag XJ40, ignition system from a Ford Granada, and I think most of the other running gear was a hybrid of Transit and Land Rover bits with some bits of Lada and Talbot Horizon for variety. Built in a couple of days and surprisingly it worked...went like a scalded cat too! Can't remember what brakes we used, but they worked well so I'm sure they weren't from the Landie. Having said that it was just a chassis, running gear, roll cage and two seats so didn't weigh much.
Every component involved was scrap even down to the nuts and bolts used.
Need to give them a shout sometime and see if it's still there and going. Know by the time I moved away it had taught several local kids the basics of driving.
Current fleet:
addo
- x 95
- x 8444
Zel, excellent
You should be on the show with skills like that!
- x 94
Re:
but what happens if you only want to travel two turds of the journeyaddo wrote:If you can't snap one off, how do you pay your fare?
Regards, malcolm.
- x 94
Re: Re:
hope its not a double decorCitroJim wrote: The buses in question don't have seats, they have toilets..
Regards, malcolm.
Zelandeth
- x 1608
I was only one of the team to be fair! Most of my work was just bolting stuff together, the complicated stuff like making manifolds from scratch (with scrap!) and making totally the wrong gearboxes fit different engines was done by the others. Scavenging the ignition system from the Granada to replace the stuffed electronic system from the Jeep (the immobiliser would also have been an issue as we had no idea where the key was) was my idea though.CitroJim wrote:Zel, excellent![]()
That poor engine can't have known what happened to it between losing both the injection system and electronic ignition! Didn't seem to mind though, even if the fuelling usually seemed a little on the rich side at higher revs (not surprising really as the carbs were jetted for a 4.2 rather than 4 litre engine), but the only issue that really seemed to cause was a little smoke when used in anger and flames out the exhaust on the overrun. We decided that fun element was worth keeping!
Current fleet:
