lexia where do i get one
citroenc5mad
Unread post by citroenc5mad »
Hi guys, was wondering where do I obtain a copy of this also I need the pin connector and everything any help appreciated.
I have looked on ebay but they all look the same I don't want to get a rubbish copy.
Only looking as EML came on again today and get fed up off paying garage fees to check it out.
Dan
x 5683
Re: lexia where do i get one
A lot of members have purchased from Easy Diagnostics, either direct or through eBay and have in the main been pleased with the equipment and after sales service.
I can't actually recommend personally as I don't own a Lexia.
There is a thread here with a ton of info and experiences.
osx
(Donor 2022)
x 15
Unread post by osx »
For -2008 Citroens any will work. For 2008- you need to be a bit more careful.
C5 X7 Exclusive 2.0 HDi Auto
citroenc5mad
Mines a 2009 x7 so I will need to be careful selecting then. Thanks for the advice. OSX
Myglaren will have a look later, at the links will get on the laptop.
Cheers again
x 2007
Unread post by Stickyfinger »
You need, a 2mb Laptop 80GB HD with Win7 32bit........64bit is a problem but with old laptops 98 serves very well. It has to have WiFi as well, either built in (best) or as a dongle.
Easy Diagnostics..I can say they were great with me, top chaps and to be able to call them regarding set up ect is worth a few more $$m over the EBay ones (you never know what you get)
SaabC5
Unread post by SaabC5 »
Easy Diagnostics are now advertising a 64 bit compatible Lexia i noticed the other day. :-)
x 2007
SaabC5 wrote:Easy Diagnostics are now advertising a 64 bit compatible Lexia i noticed the other day. :-)
but that defeats the point of keeping that crappy old laptop :)
osx
(Donor 2022)
x 15
Using mine with 64bit win 8.1 at the moment. Have also a virtual machine with 32bit XP which is lighter but haven't noticed any speed difference.
citroenc5mad
I've only got windows 7 however, I might reformat one and make it 32bit for this program, would it still run smoothly or not.
Also osx thanks for the link http://m.ebay.co.uk/itm/181671138606?cm ... C&gxo=true" onclick="window.open(this.href);return false;
Thinking off ordering that as it says compatible with windows 7.
osx
(Donor 2022)
x 15
It will run with win fine. In fact the last thing you need to do is a format as if you have the Pro or Ultimate version of win7 you get a virtual windows XP machine for free.
