C5 X7 coolant change?
centurus2400
x 4
Unread post by centurus2400 »
Not that mine uses any, but I do check the level from time to time. The coolant is a rather dilute looking blue-green colour.
I'm wondering if this is original 2008 vintage or if it has been changed.Should it have the pink type long life type in there?
If it does need changing does the 2.0 16 valve have any bleed screws like the older 8 valve?
I'm hoping this will be last mechanical job to get the car up to scratch, it is booked in at Easter to have all the wheels refurbished. The car is Aluminium Grey, and I'm having the wheels sprayed to match - I reckon it should look good :-)
vborovic
Locked user account
x 40
Re: C5 X7 coolant change?
Unread post by vborovic »
Here you go:
http://www.filedropper.com/c5cooling" onclick="window.open(this.href);return false;
centurus2400
x 4
Thank you for that info, guess I'll change the coolant next time I'm under there to change the oil. Looks straightforward enough!
osx
(Donor 2022)
x 15
Unread post by osx »
vborovic wrote:Here you go:
Does the link still work? Was going to change the coolant as it's not been done ever
C5 X7 Exclusive 2.0 HDi Auto
x 6946
No unfortunately Vborovic deleted a lot of his files before he left. We have recovered many of these, but this is one that slipped through the net, sorry.
x 1941
Unread post by Paul-R »
osx wrote: Was going to change the coolant as it's not been done ever
What is it that you want to query? Is it one of the cars in your signature?
osx
(Donor 2022)
x 15
Yes. Wanted to see what the procedure is, what type and volume of coolant etc
x 6946
The procedure is quite lengthy for a complete drain and refill and bleed, requiring (according to the procedure) the degassing operation afterwards. The Cooling Circuit capacity is 11.5 litres with the Auto box on your car. Send me a PM if you want the procedure.
sorabe05
Unread post by sorabe05 »
Hi Marc, I would appreciate the procedure how to replace coolant on Citroën C5 2.2!!
x 6946
@sorabe05:
The guide is the same for the other X7s, and is here for donating members:
viewtopic.php?t=64036
dstraz
(Donor 2022)
Unread post by dstraz »
Hi Marc, I made a donation but still seem unable to access the forum at your link. Maybe it just takes some time, or is there some trick I should be doing?
Dave
x 6946
PM Sent Dave
zachary
Unread post by zachary »
Hello Marc, made a donation but unable to see the file re coolant change process, can you help, pls? Regards, Zac
