C5 Heater fault
john alexander
C5 Heater fault
Unread post by john alexander »
Hi , I've searched this forum for an answer to my problem to no avail. Help, The heater on my 06 plate C5 1.6 estate has decided to refuse to blow hot on the drivers side . The passenger side works OK and the drivers side directs air to the correct vent but only cold . All help gratefully received , Or I sell it to an Eskimo taxi driver in Africa. regards john.
x 1240
Re: C5 Heater fault
Unread post by Peter.N. »
They have a dual zone heater so a separate temperature control flap for each side, its usually the passenger side that packs up as it has on mine, yours sounds like the drivers side. Mine can sometimes be unstuck by turning both sides to max temp before starting, or turning the problem side to min and then max while driving. There is a problem with the shaft on the servo motor.
Clogzz
x 40
Re: C5 Heater fault
Unread post by Clogzz »
http://www.aussiefrogs.com/forum/citro% ... issue.html" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... =3&t=32780" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... =3&t=36678" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... =3&t=37149" onclick="window.open(this.href);return false;
http://www.aussiefrogs.com/forum/showthread.php?t=89911" onclick="window.open(this.href);return false;
SaabC5
Re: C5 Heater fault
Unread post by SaabC5 »
Clogzz has the above link on standby for every time this issue raises its head. :rofl2:
x 2006
Re: C5 Heater fault
Unread post by Stickyfinger »
one a week then :)
hamster99
Re: C5 Heater fault
Unread post by hamster99 »
Hi John
On the facelift C5's it's not an issue generally with the length of the motor spindles but the fact the shaft on the internal flaps deteriorates over time and then shears.
You can get replacement flaps at a reasonable cost from Citroen (£65 ish I think) but it requires dashboard out to replace them. I've done this and it isn't as bad as you think.
I will post up all the previous topics I found once I get home tonight.
Before you do anything else check that it isn't the motor itself which has failed. Can you hear it whirring when you move the controls from hot to cold and back. If not then check the connections although the drivers side is a bugger to get at!!
Rob
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
Clogzz
x 40
Re: C5 Heater fault
SaabC5 wrote:Clogzz has the above link on standby for every time this issue raises its head. :rofl2:
:mrgreen: :lol: 8-)
triumphtoledo
Re: C5 Heater fault
Unread post by triumphtoledo »
The C5 II inherited its heater box from the Peugeot 407. The old motor shaft issue that afflicted the early C5s does not apply.
It will be the heater flaps.
Car Mechanics magazine will publish an article on this (in the summer).
R
john alexander
Re: C5 Heater fault
Thanks for that , I've found some videos on youtube showing how to fix this. I'm going to go the dash out route , as soon as I find out how to take the Airbag below the steering column out . If you know pass it on.
VertVega
x 13
Re: C5 Heater fault
Unread post by VertVega »
Here is the "easy way option" Cut_and_Glue route :)
(As mentioned above 407 and C5 II are both suffering the same problem :evil: )
---> PEUGEOT 407 HEATER FIX
Youtube (UK) ---> Peugeot 407 heater flap problem, part 1 and part 2
john alexander
Re: C5 Heater fault
I saw that one but as it's the drivers side there's not a lot of room and with my luck the other side would break next month.
hamster99
Re: C5 Heater fault
Hi John
The dash out route is probably the best in my view as it means you can get at everything.
If you are following the Haynes BOL then there are a few shortcuts which make it a whole lot easier, including not having to remove any airbags and taking out the steering column assembly in one piece rather than in bits like the book says.
I'm afraid I'm off to bed now as up early but tomorrow I will find all my posts on this and let you have the links. I have some photos somewhere too which might help.
Rob
VertVega
x 13
Re: C5 Heater fault
"part 1" and "part 2" videos are for the UK driver's side :)
I have the same problem which happened (Sh"t happens) 5 weeks ago. Fortunately it's the passenger's side here :-D (driver's side in UK).
As a quick solution I just taped the right side in the center dashboard and also covered the opening under the front right seat. At least I know what to do next when the weather gets a bit warmer.
