Xantia wheel studs
Eddie Nuff
New User
x 38
Xantia wheel studs
Unread post by Eddie Nuff »
I acquired two wheels with new tyres for my Xantia but when fitting noticed a slight difference where the stud fastens the wheel to the hub.
The original wheels on mine were like this
The new ones are like this
The original studs are 2 inch long
Are these wheels designed to be fastened on with longer studs?
x 1480
Re: Xantia wheel studs
Those are spare wheels from alloy-wheeled cars, and need to be secured with a bolt with a flat shoulder, and a washer. If you want to use them you'll need to get some new bolts.... :roll:
x 94
Unread post by citronut »
RichardW wrote:Those are spare wheels from alloy-wheeled cars, and need to be secured with a bolt with a flat shoulder, and a washer. If you want to use them you'll need to get some new bolts.... :roll:
i agree on the type of Rim Richard although you should be able to use tapered seat bolts as the seats on those rims not anly have a flat face, but also a tapered seat,
you might just require slightly longer bolts
Regards, malcolm.
chinkostu
x 30
Unread post by chinkostu »
I wouldn't.
Flat faced bolts have a slight taper and a washer, a tapered bolt would shear in there
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
Eddie Nuff
New User
x 38
So, considering the price of new studs, and finding the right ones, would the prudent choice be to just transfer the new tyres onto the original steelies?
x 1480
£3.50 each from the dealer - there are 2 types listed though, not sure on the difference, or which you need....
chinkostu
x 30
If you get a chance, theyre the same bolts that saxo vtr uses by the looks of it. Although i think the different part numbers are down to different lengths
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
Eddie Nuff
New User
x 38
£3 a stud, £24 in total - or a tenner to get the tyres changed over. No argument really.
