1998 Xantia full lock noise
foeism
Unread post by foeism »
Hi
I have noticed that when the steering wheel in on full lock to the left and the steering wheel can't be turned any further, as I turn the wheel to the roght to put it straight there is a load "thud" as I start to turn it from full lock.
Steering is light and never heavy....any ideas......did do a search on google, but nothing seemed to match.
thanks
chinkostu
x 30
Re: 1998 Xantia full lock noise
Unread post by chinkostu »
Top mounts. Are they looking ok or a little worn and rotten?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
foeism
Thanks for the reply :)
No rot, and they both look good. How can I tell if there worn?
thanks
chinkostu
x 30
Hmm, thats odd. Even from under the wheel arch? The reason i say is because my 206 knocked like buggery when the top mounts were gone. Droplinks and balljoints would only really knock when mobile. Could be track rod but then it'd knock every time you turned.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
foeism
chinkostu wrote:Hmm, thats odd. Even from under the wheel arch? The reason i say is because my 206 knocked like buggery when the top mounts were gone. Droplinks and balljoints would only really knock when mobile. Could be track rod but then it'd knock every time you turned.
Yeah it is strange only on full lock to the left, and only one thud like youv'e pulled something free? rather strange :?: :?:
handyman
Unread post by handyman »
Worth checking rear bushes on the front wishbone as these can provide that 'Donk' noise when badly worn. Also worth checking bottom ball joints for any movement. What are your CV joints like? No splits in the gaiters?
Handyman
foeism
handyman wrote:Worth checking rear bushes on the front wishbone as these can provide that 'Donk' noise when badly worn. Also worth checking bottom ball joints for any movement. What are your CV joints like? No splits in the gaiters?
Handyman
Hey thanks for the reply.
working lates this week, but will check and update shortly :)
Zelandeth
x 1608
Unread post by Zelandeth »
Silly suggestion based on a similar symptom I had on a Corsa years ago. Check your brake pads...I had one where the friction material had separated from the backing (but was still trapped in the caliper), and it produced symptoms very lime what you describe.
Easy check at least! Not one I ever would have expected, but a new set of pads solved it in my case!
Current fleet:
07 Volvo V70 SE D5, 89 Ford Thunderbird, 85 Sinclair C5, 84 Trabant 601S, 73 AC Model 70, 62 Rover 110.
