Hi
I have noticed that when the steering wheel in on full lock to the left and the steering wheel can't be turned any further, as I turn the wheel to the roght to put it straight there is a load "thud" as I start to turn it from full lock.
Steering is light and never heavy....any ideas......did do a search on google, but nothing seemed to match.
thanks
1998 Xantia full lock noise
chinkostu
- x 30
Re: 1998 Xantia full lock noise
Top mounts. Are they looking ok or a little worn and rotten?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
foeism
Thanks for the reply
No rot, and they both look good. How can I tell if there worn?
thanks
thanks
chinkostu
- x 30
Hmm, thats odd. Even from under the wheel arch? The reason i say is because my 206 knocked like buggery when the top mounts were gone. Droplinks and balljoints would only really knock when mobile. Could be track rod but then it'd knock every time you turned.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
foeism
Yeah it is strange only on full lock to the left, and only one thud like youv'e pulled something free? rather strangechinkostu wrote:Hmm, thats odd. Even from under the wheel arch? The reason i say is because my 206 knocked like buggery when the top mounts were gone. Droplinks and balljoints would only really knock when mobile. Could be track rod but then it'd knock every time you turned.
handyman
Worth checking rear bushes on the front wishbone as these can provide that 'Donk' noise when badly worn. Also worth checking bottom ball joints for any movement. What are your CV joints like? No splits in the gaiters?
Handyman
Handyman
foeism
Hey thanks for the reply.handyman wrote:Worth checking rear bushes on the front wishbone as these can provide that 'Donk' noise when badly worn. Also worth checking bottom ball joints for any movement. What are your CV joints like? No splits in the gaiters?
Handyman
working lates this week, but will check and update shortly
Zelandeth
- x 1583
Silly suggestion based on a similar symptom I had on a Corsa years ago. Check your brake pads...I had one where the friction material had separated from the backing (but was still trapped in the caliper), and it produced symptoms very lime what you describe.
Easy check at least! Not one I ever would have expected, but a new set of pads solved it in my case!
Current fleet:
