c5 exclusive headlights self levelling
scottspark
Post by scottspark » 20 Nov 2014, 01:50
Hi can self levelling headlights be adjusted by the plastic screws on the headlights. The beam is very very low. If they can be adjusted will this have any affect on the self levelling motor.
2008 on c5 exclusive
vborovic
Locked user account
x 15
Re: c5 exclusive headlights self levelling
Post by vborovic » 20 Nov 2014, 07:26
Maybe one of the height sensors is off, or damaged (there should be one on each wheel's suspension rod, somewhere) ... Lexia session maybe to check for any errors regarding wrong readouts? ...
scottspark
Post by scottspark » 20 Nov 2014, 09:37
Thanks iam did read about that. Hopefully don't want to spend money so was wanting to see if they can be adjusted.
h2ocooler
Post by h2ocooler » 20 Nov 2014, 18:58
Yes they can be adjusted and it will not affect the self levelling but you will need to have it on level ground when you adjust them. I did mine on my C8 and also my dads on his C5.
Do they move up and down when you start the car in the dark with the lights on auto or turn the lights on?
scottspark
Post by scottspark » 20 Nov 2014, 21:32
Hi yes they move up and down when I turn them on but just aim to low.
Xantippa
x 13
Post by Xantippa » 21 Nov 2014, 08:51
Check the height sensor on rear axle. It´s rusty if you haven´t lubricated it, and I think that affects the lights too.
Something like this in the middle of the rear axle:
It´s easy to access when you lift the car up, but remember to use some support so you won´t get squashed in case the rear falls down!
