c5 exclusive headlights self levelling
Post Reply
scottspark
My Cars:
Post by scottspark »
Hi can self levelling headlights be adjusted by the plastic screws on the headlights. The beam is very very low. If they can be adjusted will this have any affect on the self levelling motor.
2008 on c5 exclusive
vborovic
Locked user account
My Cars: A used Citroen
x 27
Re: c5 exclusive headlights self levelling
Post by vborovic »
Maybe one of the height sensors is off, or damaged (there should be one on each wheel's suspension rod, somewhere) ... Lexia session maybe to check for any errors regarding wrong readouts? ...
scottspark
My Cars:
Thanks iam did read about that. Hopefully don't want to spend money so was wanting to see if they can be adjusted.
h2ocooler
My Cars:
Post by h2ocooler »
Yes they can be adjusted and it will not affect the self levelling but you will need to have it on level ground when you adjust them. I did mine on my C8 and also my dads on his C5.
Do they move up and down when you start the car in the dark with the lights on auto or turn the lights on?
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
scottspark
My Cars:
Hi yes they move up and down when I turn them on but just aim to low.
Xantippa
My Cars: Now:
C5 X7 HDi 240 Exclusive Tourer
ZOE 22kwh Intense
Before:
C4 1,6 Coupe Automatic
C5 X7 HDi136 Exclusive Sedan A
Xantia HDi110 Berline
Xantia 1,8SX Berline
x 28
Post by Xantippa »
Check the height sensor on rear axle. It´s rusty if you haven´t lubricated it, and I think that affects the lights too.
Something like this in the middle of the rear axle:
It´s easy to access when you lift the car up, but remember to use some support so you won´t get squashed in case the rear falls down!
Post Reply
